Professional Controller won't see any devices, says "Disconnected"
Discussion in 'Phantom 3 Help' started by Adam Kontras, Sep 21, 2016.
  1. Adam Kontras
    Los Angeles, CA
    Last time I used my P3P was in March simply for the steadicam capabilities. Held it while doing some "walk-overs". Everything worked fine.
    Powered it up two days ago and it would NOT see my device (iPhone 6 plus). It still works mind you, I can move the camera, etc... but when I hit "camera" nothing appears and it says "Disconnected"
    -I've tried 3 different cables, all that work with regular chargers no problem, still says "Disconnected".
    -Reinstalled the app multiple times... which also means that the "Camera" button is gone, it simply says "How to Connect" on the app, so I can't even get into my settings.
    -used 3 different devices (iPad Pro and an iPhone 6) at 3 different ios levels (from ios10 TODAY to the previous updates), it never sees the device.
    -thinking the USB port was broken I plugged several devices in while the controller is on and, voila - it was able to power those devices (an external harddrive and started charging my fitbit)
    The ONLY thing that was changed from when it worked fine several months ago to today, are the updates to the DJI app. I have since updated the firmware for the quad itself (no problems) but of course cannot update the controller since it now needs the app to do so. DJI support just wants me to send in the controller because they figure the USB port must be broken, but how could it power other devices?!?!
    Any ideas? And yes, I've scoured these forums, but most of the threads end up unanswered or one of the fixes I tried worked for them...
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    When did you last upgrade the firmware on the remote controller?
  3. Jonathan Huff
    Michigan
    Mine was doing that, I just updated the DJI app on my tablet. It was fine after.
    I also turn on the controller first , then the drone.
  4. Adam Kontras
    Los Angeles, CA
    I have 1.4 on the controller... so I can no longer upgrade it manually (how remarkably stupid is this, DJI?)
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Did you try reinstalling DJI GO?
  6. Adam Kontras
    Los Angeles, CA
    "-Reinstalled the app multiple times... which also means that the "Camera" button is gone, it simply says "How to Connect" on the app, so I can't even get into my settings."
    Literally been doing this for 6 hours.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Yes, I did see that. Re-quoting it doesn't really add much clarity though. Are you saying you reinstalled DJI GO before or after you installed new firmware on your Phantom?
  8. Adam Kontras
    Los Angeles, CA
    I did it before and after.
    And again, I could control the phantom fine before I updated the firmware and after. No issues there with the controller...
  9. Multicoptertec
    Apollo Beach, Florida
    I'm confused. The CAMERA button is available BEFORE you actually get into the Go app, so if you cannot select it, how are you able to control the camera or get messages about disconnects?
  10. Jonathan Huff
    Michigan
    I know the camera button is grey, once the connection from the display device to the controller is confirmed it turns blue
    I had this problem and i fixed it by updating the app and just using a different cable
  11. Adam Kontras
    Los Angeles, CA
    Before I uninstalled and reinstalled the app, the blue camera button was there. I would press it and the app would say the camera was disconnected. Even though I had full control of it. I had an iPad Pro that NEVER had the DJI app, decided to install it and see if it worked... no blue camera button, simply says "HOW TO CONNECT" in the bar. Doesn't see the device at all. On my original device (Iphone 6 plus) once I uninstalled and reinstalled the app, it never again showed the camera button, just the "HOW TO CONNECT" in the bar.
    THroughout all of this... I have had full control over the gimble and quad... it's bizarre.
  12. Adam Kontras
    Los Angeles, CA
    (and thank you for talking me through this. I'm certain there's an easy fix because the controller CAN power other USB devices - there's no way I'm sending this back to DJI because of some software gimp)
  13. Jonathan Huff
    Michigan
    It's just odd
  14. Adam Kontras
    Los Angeles, CA
    There is no grey camera button for me once I uninstalled the app the first time. It acts as if nothing is connected and there's a giant "HOW TO CONNECT" button that any of you can see if you just change the drone type to a different model...
  15. Adam Kontras
    Los Angeles, CA
    Odd is one word for it. I've come up with a MOTHERFU$*&^W few other ones since 11am when this started.
  16. Multicoptertec
    If you have ever connected to any aircraft type with a device, you can always get into camera mode (into the go main screen) without a controller/aircraft connected. My question, again, is how can the op control the camera, or get disconnect messages without getting past the camera button?
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I don't think he can. He's just not good at laying out his timeline in the proper order ;)
  18. msinger
    Approved Vendor
    Harrisburg, PA (US)
  19. Adam Kontras
    Los Angeles, CA
    I open the DJI GO App.
    I select my model.
    A blue CAMERA button appears.
    I hit it.
    Within the next screen it's totally blank and says I'm disconnected even though I have full control of the quad.
    Once I reinstalled the DJI GO App however, when I open the app there is no longer a CAMERA button to select. It just says (everybody) HOW TO CONNECT.
    Not sure how else to explain it. You can absolutely open the DJI Go app without it being connected to the camera. And you can operate your drone with or without the DJI App being open OR connected. Bottom line: the controller does not recognize that my devices are there.
  20. Multicoptertec
    The USB connection has both power and data. Just because there is power available to charge, doesn't mean the data is flowing.
Similar Threads - Controller won't devices Forum Date
Professional RESOLVED: Remote Controller Won't Connect To Aircraft Phantom 3 Help Aug 9, 2017
Pretty soon, you won't have to call us air traffic controllers anymore :) General Discussion Jul 29, 2017
P3A Won't connect to controller Pro/Adv Discussion Jul 16, 2017
Phantom 3 4k controller won't charge past 2 LEDs Standard/4k Discussion Jul 9, 2017
Dropped phantom 4 pro controller won't stop beeping Phantom 4 Pro Help May 7, 2017
