  1. Raphael
    Hey guys, when I try to calibrate my controller it won't register the left stick moving to the left, so when I launch the drone without calibration it just perpetually spins. Is there a way I can just completely reset the controller?
    Thanks!
  2. Raphael
    I called DJI and they said to try resetting my controller by holding down c1, c2 and the right wheel and power it on and off. But that did nothing. Any thoughts?
    Mark The Droner likes this.
  3. Mark The Droner
    If it won't show the left stick moving to the left, it seems something is wrong with your controller. Sounds like warranty service to me. Otherwise, open it up and try to see what is going on with the left stick control.
  4. Raphael
    any idea how to open a phantom 4 remote?
  5. Mark The Droner
    I don't have a P4 but if you click on the little magnifying glass icon in the upper right corner and then type in the key words "P4 mod" you should find a thread that will give you a clue on how to open that boy up
  6. Pharm
    Remove the screws that are holding it together, then open slowly.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Doing this will most likely void the warranty on it, but you can open it like this:
Similar Threads - Controller calibrate Forum Date
Controller stick unable to calibrate Phantom 4 Help Sep 4, 2016
Cant connect controller to calibrate? Any Ideas? Phantom 2 Help Aug 12, 2016
Calibrate controller Phantom 3 Help Jul 3, 2016
Controller for my P2 will calibrate all but 1 correctly Phantom 2 Discussion May 20, 2016
Cannot Calibrate Upgraded Controller to Old Version of P2V+ Phantom 2 Vision + Discussion Jan 5, 2015
