Controller stick mod
Northwest USA
Precise movements are sometimes needed in and around objects on the ground. I made these from cheap hollow plastic golf balls and ping pong balls with a ball point pen cover as the female adapter to the stick. They also prevent a CSC death command. Epoxy holds the stick adapter solid to the ball.
Reactions: Mark The Droner
How do you get the precise control with this arrangement?
Tested short flight. I made them for moving tightly around courses/objects for smooth pan shots. Havn't had the chance for a real test as I have been persuing amplification/antenna issues. When I dream up a project then it will be fully tested. Precise movement should be possible by just lightly touching ball. The expanded diameter translates to a smaller stick movement .
