Controller S1 switch damaged
Need help. My S1 switch broke off in transit. Can I use the S2 switch as a replace since it is not in use as yet. How do I make the switch?
Thank for any assistance.
PS. Lesson learned. Get a case for the Vision.
If you're good with a soldering iron you can easily replace the s1 switch. I've also read a thread in here some time ago when someone ended to do that. The s2 switch actually can be assigned other functions and also is used to reset home position so you will really need to get your s1 switch replaced.
Transit? as in when It was shipped to you? File a claim? If not you can easily do some soldering to fix it
Pauos31
