Controller Beeping During Flight
Discussion in 'Phantom 2 Vision + Discussion' started by MapMaker53, Aug 7, 2015.
  1. MapMaker53
    Long Island, NY
    I have the original RC powered by AA batteries. Recently while I was flying, the RC began beeping non-stop. Nothing bad was happening on the screen, so I just assumed it was the AA batteries that had reached a low threshold of some sort and I got my Phantom back to me in a hurry and landed. (I usually change the AA's out every 15 flights or so, even though a battery checker shows them as still being good.) I popped a new set of AA's into the RC and it hasn't beeped since.
    Does anyone know about how much time one has before losing control signal once that RC battery warning beeping starts? I don't recall reading anything about that.
  2. 4wd
    4wd
    North York Moors
    You could probably do several more flights, at worst the Phantom will RTH
    Obviously the sensible thing is to change them ASAP.
    If you were out for the day without spares, the beep is only a warning they need changing soon and no need to abandon a planned flight.
  3. RoyVa
    Virginia
    I did an additional flight then I got pucker power and went home and got some more.
  4. MapMaker53
    Long Island, NY
    I aborted the mission mostly because I didn't know how much time I still had on the controller, but also because the constant beeping of the RC was just so annoying. Obviously meant to not be ignored, which I can appreciate. I know it would Failsafe return to home with GPS if the RC ran out of power, but it's not good practice to just keep flying and rely on that.
Similar Threads - Controller Beeping During Forum Date
Controller Beeping During Flight? Pro/Adv Discussion Mar 21, 2016
Standard Beeping and flashing light on controller? Phantom 3 Help Jun 16, 2017
Dropped phantom 4 pro controller won't stop beeping Phantom 4 Pro Help May 7, 2017
Phantom 4 constantly beeping when turned No connection to computer or controller Phantom 4 Help Apr 25, 2017
P3P Controller Constant Beeping After Antenna Mod Pro/Adv Discussion Apr 10, 2017
