Controller beep twice, in CE mode as well ?
Discussion in 'Phantom 2 Vision Discussion' started by isopro, Aug 19, 2014.
  1. isopro
    Yesterday during a Ground station 500m range mission, i lost Control Link at arround 490m, so i checked my battery voltage and everything seem ok, then i tryed to see if i could switch to CE mode and screwed the lower screw on the back of the transmitter counter clockwise, turned controller on, 2 beeps again. So i plugged controller into pc and noticed it was still FCC mode even with the screw counter clockwise, switched to CE in software, turned off controller and back on, 1 beep. So i putted the screw in FCC mode with software still in CE, turned the controller, 1 beep with screw fully clockwise in CE mode...
    Do anyone know what is the real FCC mode and real CE mode, because now im confused, i can get 2 beep with screw in both positions, and 1 beep with screw in both positions, controller came stuck in 2 beep mode with screw fully clockwise and only give me about 490m range. And the screw look like its doing nothing on the beeping. I wish i add something to check rf power of my controller in all those 4 possibilities...
    Anyone seen this ?
  2. Geoelectro
    Houston Tx.
    I just tried mine. Fully CCW, one beep. Fully CW, 2 beeps. Bottom adjustment of course.
    Geo
  3. isopro
    This is a Video of me trying, with the screwdriver,
    [youtube]https://www.youtube.com/watch?v=xoNxLSEV3u0[/youtube]
    And an image of the inside of my controller
    [​IMG]
    It's like the screw do nothing, to the controller beeps, but does it change the power output is the question im asking myself, and maybe it works reverse, i really wonder...
    If i set it to CE mode in my computer, i only get 1 beep after, but if i turn the screw fully clockwise it stay at 1 beep only..
    You do the adjustement when the controller is turned off, anything i did wrong ?
    P/S: I've the controller with the USB port outside...
Similar Threads - Controller beep twice Forum Date
P4ProPlus controller that beeps softly while OFF? Phantom 4 Pro Help Friday at 11:31 PM
Controller light went from red and beeping non stop to blue and silent Pro/Adv Discussion Sep 29, 2017
Drone Beeps and can't connect to controller Phantom 4 Help Sep 2, 2017
Controller trouble-beep-HELP General Discussion Jul 28, 2017
Standard Beeping and flashing light on controller? Phantom 3 Help Jun 16, 2017
