control sticks on controller(p3a)
Discussion in 'Pro/Adv Discussion' started by hammer737, May 19, 2016.
  1. hammer737
    hello....today the right stick assembly in the controller has become loose, as such that when pushing the stick in all directions actually moves the stick but now the entire directional guides housing (black coloured) around the stick moves down(1/8th inch) and is slightly sloppy once this happens...I can pull it back up using the stick...but does not stay in original factory position....b4 I take it apart to look and repair..has this happened to anyone else.
    cheers all
    #1 hammer737, May 19, 2016
  2. BDOG
    San Jose Ca and Lake Tahoe NV
    Open the remote and glue (probably voids warranty) or send in to DJI and wait for a lengthy repair process.
  3. hammer737
    fixed....as suspected.....inside remote the white plastic mounts where the entire control stick assembly are attached to inside of remote body were cracked so the stick assembly had moved off the mount and slopped around inside remote. taped down to original placement and used a small amount of plast-aid around each mount. let hardened and are now good as new....suspect over-tightened from new.
    thanks BDOG for the info.
  4. Oso
    Oso
    Western US
    Sadly this is a very common problem. That and the RTH button breaking.
Similar Threads - control sticks controller(p3a) Forum Date
Standard Lost both control sticks Phantom 3 Help Sep 4, 2016
P3 controller sticks too sensitive Pro/Adv Discussion Mar 30, 2016
Question on controller sticks Standard/4k Discussion Sep 13, 2015
Diameter of the control sticks on a Solo Off Topic Jun 30, 2015
Lost Forward and Backward on Control Sticks Phantom 2 Help Mar 21, 2015
