Control Phantom v1.1.1 via PC?
Discussion in 'General Discussion' started by iversens, Jan 22, 2014.
  1. iversens
    San Jose, CA
    Is it possible to control/fly a Phantom using a transmitter attached to a PC?
    I'd also like to know if anyone has figured out how to program the NAZA to fly and land at a specific GPS location. Basically, how to hardcode the "home" location so it uses auto-pilot to fly to a different location than where the Phantom was powered on?
    I'm having fun with my new Phantom and looking to add non-conventional upgrades such as "grippers" to carry a ball.
    Thanks.
  2. OI Photography
    Clarksville, TN
    DJI's DataLink (2.4GHz or 900MHz) is what you're looking for. It'll let you control the phantom from a PC (or iPad) via a dedicated radio link to the aircraft, and program waypoints (up to 16) on a visual map interface.
    http://1uas.com/2-4Ghz-Bluetooth-Data-L ... _name=data link
    Note: you'll need to add a PMU to the Phantom to be able to install the DataLink transmitter (it needs a canbus connection)
  3. FatKevinSmith
    Don't NAZA-M V2 equipped Phantoms (like the v1.1.1) include the independent PMU?
  4. OI Photography
    Clarksville, TN
    I didn't think they did but I could be wrong, I have a 1.2...if it's in the 1.1.1 already then it won't need to be added.
  5. adam12hicks
    No. I have a 1.1.1 and needed the PMU to add my ZenMuse Gimbal. Only the P2's have the PMU integration as far as I know. I decided on the upgrade board, which I MUCH prefer over using the GCU + PMU + rat's nest of wiring to retrofit. The upgrade board is so nice and clean... BUT it doesn't give the same CAN bus connectivity either, so that wouldn't help you here.
Similar Threads - Control Phantom via Forum Date
Easiest way to control the DJI Phantom via software? General Discussion Dec 9, 2013
Phantom 3 Advanced controller upgrade Pro/Adv Discussion Yesterday at 5:44 PM
DJI Phantom 4 Remote Controller Classifieds Tuesday at 9:15 AM
Phantom 4 controller charging problem Phantom 4 Discussion Tuesday at 8:48 AM
Phantom Camera Feed Froze and Flight Controls Became Slow to Respond General Discussion Aug 10, 2017
