Control multiple Phantoms
Discussion in 'Pro/Adv Discussion' started by anaskh, Mar 21, 2016.
  1. anaskh
    Dear All
    Good morning. I am looking for a way permits me controlling many phantoms pro 3 together and simultaneously.
    It will be very kind of you if you can help me..
  2. Waylander
    West Yorkshire, UK
    Why would you want to.......
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    A Phantom can only be paired to one remote controller at a time. So, you'd need to be operating multiple remote controllers simultaneously in order to do what you're suggesting.
  4. N017RW
    Palm Beach Co.- FL
    The technology exists and has been demonstrated by universities and industry with purpose-built multi-rotors but is not yet commercially available.
    It requires lots of computer 'resources'.
  5. Rock Shelter
    I've heard that the 4 can be used to follow other GPS drones (or any other GPS device). you are probably looking for swarming techniques. this is not that, but getting there.
  6. N017RW
    Palm Beach Co.- FL
    More internet myth...The P4 is capable of tracking other objects but has nothing to do with GPS. Just how robust the 'follow-me' feature is will be posted here as time goes on.
  7. Dadcat
    Portland Area, Oregon
    The question is whether more than one Phantom can be paired to a single remote controller the way you used to be able to do with Blade 350QXs. Like this:
    I doubt it though, since unlike the old 350, there is a lot of 2 way communication going on between a P3 and its RC.
  8. alokbhargava
    San Francisco, CA
    Current RC can't control multiple P3s simultaneously.
    Let's assume that somehow one hacks to connect two P3s to one RC, then RC will remember only one position at any time and will make them collide in air. This may require offsetting x-y-z coordinates on the P3s. This is an interesting problem to solve but we can't do unless FW is hacked.
    #8 alokbhargava, Mar 21, 2016
  9. PrecisionAeroworks
    Colorado, USA
    You can use Universal Ground Control Station station to do this.
    Ground Station Software | UgCS PC Mission Planning
    It is a PC based mission planning system. It uses a mobile app to connect to and fly the drone, and if you have multiple mobile devices connected to multiple drones on the same local network, you can simultaneously control multiple drones from the same PC.
    Live "click to fly" for multiple P3/Inspire drones on one map on the PC.
    #9 PrecisionAeroworks, Mar 21, 2016
  10. alokbhargava
    San Francisco, CA
    OPs question was about one controller and multiple phantoms.
  11. PrecisionAeroworks
    Colorado, USA
    Where do you see that in the question? Plus, that's impossible anyway with this system.
    He only asked about controlling multiple phantoms simultaneously. This is the only way to do that, AFAIK.
  12. alokbhargava
    San Francisco, CA
    May be I misunderstood. Yep, he didn't explicitly say "multiple phantoms with single controller". Our mind keeps on assuming things that are not clearly said.
  13. PVFlyer
    Hong Kong
    How about to create a waypoint mission and copy/sync the mission file to multiple devices. Then run the mission on all Phantoms at the same time to let them dance together.
  14. N017RW
    Palm Beach Co.- FL
    Problem is they'll all drift or diverge as they are not equal.
  15. alokbhargava
    San Francisco, CA
    It would be interesting to watch multiple phantoms flying in synch maintaining a safe distance between them.
  16. anaskh
    thank you all for your replying, I need to know the protocol of controlling P3P so I can develop a program allows me to control multiple P3P simultaneously
  17. Dome
    Italy
    Something could be done with Inspire 1 controllers, they are equipped with a 5ghz trx that can sync controllers each other...
  18. DrJoe
    You'd be much better off building purpose built quads with arduino computers. There is some open source stuff for swarming drones, but it requires two way communication and central computer controlled processing. It prioritizes a"leader" drone's telemetry and data and synchs the others positions to it by a simple offset of gps position and timed repositioning.
    I have read some reports of non-centralized control, with a leader making autonomous decisions for a given flight path.
    I imagine it is done this way: Each drone is given a leadership priority, with each drone being the lead for the subsequent drone. The prime leader drone then broadcasts its position which is followed by a polling of that leader's telemetry by the next in line using a timed response and a predetermined offset of the leaders interim waypoint. The offset position is randomly generated by the subsequent drone so that a pattern of behavior does not develop. Before the waypoint is reached, the process is cycled so that the swarm moves in a continuous wave without starting and stopping.
    I.d imagine the military is researching primarily autonomous control that could work like this: Once the leader drone is given a waypoint and target, it becomes autonomous. At a given "target" point, the lead drone selects its target, tracks it (just like a phantom 4), and stays in motion. The leader shares the information with its followers. This is repeated until all drones aquire the target at randomly generated offset positions. Instead of targeting with a camera, a gimbal stabilized weapon is used. The biggest challenge would be signal security and hardening the drones against disruption by jamming in a battlefield environment.
    That's a boatload of coding and engineering outside of a university or a major collaborative effort. But it works. If your that good, I'm sure DARPA is looking, especially at Virginia Tech. Keep us posted on your efforts.
    #18 DrJoe, Mar 23, 2016
  19. anaskh
    Dear Mr. DrJoe
    Thank you very much for your suggestions. But I need something different.
    What I need exactly is a computer interface - Can be Labview interface - that allows me controlling two drones simultaneously.
    I could not find a ready interface online, so I am thinking of developing one. And in order to do, I need to know the communication protocol used in Phantom 3 Pro. I need also to know if there is any open source code for P3P in which I can know the proper language and instructions for P3P.
    Best regards
Similar Threads - Control multiple Phantoms Forum Date
HowTo: Shoot Multiple POIs/Scapes in 1 Cut w/ Basic Drone Moves, Cinematic Tutorial/Controls/Tips 4K Photos and Video Apr 21, 2017
Multiple Phantom 3's on one controller General Discussion Oct 17, 2015
Advanced Is it possible to link multiple controllers to the phantom? Phantom 3 Help Sep 23, 2015
Multiple P2 5.8Ghz controllers with RE700s and phone holders and other P2 parts Classifieds Jun 15, 2015
Multiple Vision controllers Phantom 2 Vision Discussion Apr 2, 2014
