Constants BEEEEEEP
Welcome,
I am writing to the state with such a large request. After switching Phantom and app / pilot had to register, to name Phantoms etc, this was successful.
After being shown a window with Firmware Update or Skip. I took Update. On the SD card, before the formatted in FAT32, I have uploaded the file .bin latest firmware version from Dji, probably about number 1.9.6. I turned off the drone, I put the SD card. Drone ON, gimbal moved, LEDs blink, drones seem beep, beep, the cam LED flashes red and green. It looks properly update the firmware. After about 15-20 minutes, the drone began to seem constans sound BEEEEEP, the LED does not blink already red and green, only red. The log Update Failed, and more specifically what those of my screenshots: 1. https://s12.postimg.io/pa0rz4x1p/20160831_141005.jpg 2. https://s18.postimg.io/4wxwh8lhl/20160831_141102.jpg
When Throw everything from SD and drone ON is something there loads, app shows a red NO SIGNAL, the screen is black.
Such BEEP constans happening now all the time no matter what version of firmware dam on the SD card, immediately after a while and squeaks continuous sound and the red LED burns over cam.
SORRY MY BAD ENGLISH!
Please help me.
It sounds like you're saying you installed the remote controller firmware from within DJI GO and then the Phantom firmware after that. If that's true, then you should downgrade the remote controller firmware (like this) and reinstall the firmware by following these instructions.
Please follow my instructions above.
Ok I was able to go back to version 1.1.8 I can make updates by app 1.5.8> 1.6.0
But the drone is still the same. Beeeeeep constans, why? :(
Did you try updating the firmware on your Phantom? If that's when it's beeping, then let it continue to beep. It could take up to 30 minutes to get past the beeping.
So I tried. Constant beep begins at the moment when the drone correctly update firmware, and for a moment (~2-10min) the constants beep. And LED on the camera lights red (can not blink red-green).
Please tell me what are these logs?
1. https://s12.postimg.io/pa0rz4x1p/20160831_141005.jpg ---> Device not found? Does this mean broken camera module?
2. https://s18.postimg.io/4wxwh8lhl/20160831_141102.jpg ---> Is he here loses communication with the RC? But RC must be OFF when the update Phantom.
Try removing and reinserting the cables in the top of the gimbal.
That's a history of the Phantom firmware install attempts. You will not see RC related messages there.
It did not work.
But I put the drone a blank SD card. Drone ON, RC ON, APP ON. It is a black screen and NO SIGNAL. Shows versions: APP 2.8.4 RC 1.5.8 Drone 1.9.6 but something wrong updated. Photo l do and I do the video recordings. I can see it on the computer when I put SD from drone to the PC. Records video work and takes pictures, but there is still NO SIGNAL and the screen black on APP.
Have you tried to rule out the device (tablet,phone) and the cable you are using to connect the device to the transmitter?
Sent from my Verizon Galaxy Note4 using TapaTalk
kprf, it looks like you're going to need to contact DJI support for help.
wkflysaphan4
