Hello Ernest,Recent had a small crash and now one propeller will not start, and also a constant beeping. All three other propellers start up fine.
Hello Ernest,
Sorry bout your misfortune! BUMMER!
Can you let us know a little more, sounds like you possibly toasted a speed control? Also depending on how hard you crashed, and what you crashed into, might be a good idea to open her up, check for damage ( especially your GPS unit under the top casing of phantom, it has a CERAMIC antenna, and can crack EASILY! )
Also the beeping, is it a constant beep beep beep beep? And is it only coming from the one speed control?
You might have a jammed motor, or debris, or bent shaft?
If you can tell us exactly what it is doing upon startup. Lights , sounds, ect.
Also try spinning motor in question, does it spin freely 360 degrees? If not, take apart motor inspect for debris or damage. They are aluminum, and can damage if hit right!
Let us know thanks
J Dot
