My apologies if this have been posted/discussed before. I have scrolled through posts back to July but not found anything on topic.
My P2V+ took a bath. I cleaned it up and got it back to life, but after self-test procedure I get continuous quick flashing lights ("Transmitter Signal Lost")
What works:
Thanks in advance.
What works:
- - Camera + Gimball works; also video link to Android phone.
- Tx checks out fine in "DJI RC System Assistant" software (v 1.1)
- Tx binds to Rx just fine. Binding process works as it should.
- P2V+ connects to P2V+ Assistant software (v 3.2) and firmware upgrade to v. 3.06
- - No ability to calibrate Tx through P2V+ Assistant software. I get CFG-ERR ("Configuration error, this may cause by firmware upgrade from old version.or abnormal Tx calibration. Re-calibrate your transmitter,and power cycle your controller and check all of the parameters."
- - Replaced Rx unit = no change to behavior
- Replaced main controller (Orange box) = no change to behavior
- Replaced all cables
Thanks in advance.
