Considerable gimbal tilt during high speed turns
Discussion in 'Pro/Adv Discussion' started by acetmr, Apr 9, 2016.
  1. acetmr
    A couple days ago I was flying over a Marina and noticed some severe horizontal gimbal tilting when making turns at near max speed.
    I also noticed similar issues when just hovering even after multiple IMU, compass, and gimbal calibrations. Yes they were on a level surface. Does anyone know a fix for this? Thanks
  2. With The Birds
    Australia
    Are you saying your gimble can't tilt severely enough to keep the horizon level or the horizon is severely tilted in your video?
    Have you made sure there is nothing obstructing the gimble movement. Have you had a crash? Fitted filters/lens hood that may be outside the limits without counterweighs?
    There are limits. It's not unusual for things to get a little off when pushing hard. Smooth video that people will enjoy watching needs smooth piloting. Rapid pans, sharp turn and other harsh manoeuvres are very unappealing to most people.
  3. acetmr
    I've been doing aerial videography for a couple of years. Never sharp turns, ETC. Everything is stock and the craft is like new. Never even tipped over. Pushing the gimbal limit does sound like it could be the root but seems unlikely as I'm not seeing landing gear in the frame and I'm not tilting the craft severely.
  4. With The Birds
    Australia
    Ok, so your doing gentle turns at Max speed. Max speed = full available forward pitch so the camera must tilt upwards to maintain the framing. Did you apply yaw only in the turn or where you combining some pitch? The gimble is surprisingly good but it has limits. In my case they seem to be inside the performance capability of the AC.
  5. Oso
    Oso
    Western US
    Tilting and drifting horizons are reported very often. I think there were two threads just this week. Well now three with this one. A search on horizon will probably return more than a hundred posts, but here was my understanding back in October.
    Most Annoying P3P Problem - Gimbal horizon not level
    JoBe likes this.
  6. Bulman
    England/Sea
    You are able to adjust the tilt manually mid flight, as I noticed this happened to me the other day.
  7. Erroll
    South Africa
    Have you confirmed that your gimbal is still set to 'follow' and not FPV? FPV mode will have the effect of the gimbal 'tilting' as you bank the quad.
  8. 4wd
    4wd
    North York Moors
    Agree, it sounds like this.
    It isn't clear from the names which is which.
    Justin Namon likes this.
Similar Threads - Considerable gimbal tilt Forum Date
Phantom 4 pro gimbal buzzes after newest firmware update Phantom 4 Pro Discussion Yesterday at 9:49 AM
gimbal vibrations finally solved Standard Yesterday at 4:59 AM
Gimbal problem .... Standard Monday at 3:21 PM
Phantom 3 standard Gimbal error(help me) Standard Monday at 9:47 AM
Gimbal Phantom 4 Pro Discussion Monday at 6:45 AM
