CONNECTION PROBLEM - PLEASE HELP
Hi, I have a phantom 1, recently I took it apart and when I put it back together, when I power it on, apparently the transmitter is not communicating with the phantom too good.
The status light blinks green and red, even if the transmitter is turned off, and then it goes to solid green.
I tried flipping the gps switch to calibrate the compass, but that didnt work either...
Any ideas?
As you have previoudly took the bird apart, in my opinion the first step to make would be to check each and ever connector. If that doesn't bring the solution, I would recomment to rebind the tx to the bird.
magrelo1 said:
how do you rebind the tx?
You find the instructions for (re-)binding on page 19 paragraph 5.7 of the User Manual v1.6 of dji.
After some research, I found out I have v 1.1.1 with 2 antennas, which doesn't show on the owners manual for the re-binding.
I believe part31 is defective, since on all the forums it says something about a small button to press inside the bird, but mine that button is missing...
I ordered a new part31, once it arrives I will post the results.
Hopefully this will work....
