Standard Connection issues P3S to iPhone 6
Discussion in 'Phantom 3 Help' started by Guzziknight, Sep 6, 2016.
  1. Guzziknight
    I've had a couple of times where the remote connects to the phone and the bird, but the bird won't connect to the phone. No transmission of the image. I've shut everything down and tried again, but still no luck.
    Then, I move it 10 feet away, start it up, and everything connected and worked fine.
    Is this normal? Is it just a position issue, maybe some interference? Or could it be a fault in the bird?
    Thanks!
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Do you still see the problem if you enable airplane mode and then turn on Wi-Fi in the iPhone Settings? If so, what happens if you just keep your phone 10 feet away?
  3. Guzziknight
    I didn't even think of that. I'll try it and see how that works. Thanks!
  4. Guzziknight
    I flew today. Turned on Airplane mode and wifi, and turned everything else off. Worked perfectly. Connected up quickly, and didn't even flicker while flying.
    Thanks for the advice!
Similar Threads - Connection issues P3S Forum Date
Standard WiFi Connection Issues Phantom 3 Help Apr 2, 2017
P3 Firmware RC connection issues Firmware Feb 28, 2017
Connection issues General Discussion Feb 21, 2017
Phantom 3 Pro & Inspire x5 - Disconnection issues from 5m-100m away Surveying and Mapping Jan 30, 2017
Issues with battery connections on new she'll replacement Pro/Adv Discussion Jan 25, 2017
