Compass error after an emergency landing on the roof of a building.
Norway
Hey. Today the following happened. My drone made an emergency landing on the roof of the building (landing because of low battery power). The drone with its screws touched the wire. No damage - I replaced one screw. Charged the battery - took off - compass error. I calibrated the compass - the error does not disappear. Give advice on how to fix the problem.
Meta4
Moderator
Staff Member
Premium Pilot
A common cause of a compass error is having a disconnected compass.
Go into the Sensor section of your app settings and see what it tells you about the compass.
If it's disconnected, it won't calibrate until that's fixed.
The cause of disconnection could be a broken wire in the landing gear or a loose connection to the mainboard.
Oso
Premium Pilot
Western US
Are you saying that one of your props touched a wire as your drone was landing on the roof of the building and that you replaced the prop?
Did you do the compass calibration while still on the roof? Were you able to complete the compass calibration or did you get an error during the calibration process?
Kansas
YOU Better Be more careful.......In your future drone flying......You might not be so Lucky to still have a Drone in "one piece" like you do with ONLY a malfunction of a internal instrument and with the next low battery and "Emergency Landing" You might Not be
so Lucky !
Them screws are very very tiny......you say you replaced one...just where did you get it at or from ?
Wausaukee Wisconsin
If your talking the screws that hold the cover of the compass, those are special non magnetic screws. Normal screws will cause compass problems
Norway
What wire? Why did you replace a screw? Make sure you calibrated correctly. Try to calibrate again in a different place.
I do not know which wire touched. Maybe 220 volts. A little cracked screw. I calibrated the compass in different places. Calibration does not help
Norway
Understood. Thanks for the advice. Tomorrow afternoon I will disassemble my drone and check the wire from the compass
Norway
Calibration is always successful. It passes successfully in any location.
Norway
so Lucky !
I replaced the screw or propeller. translator translates badly.
Norway
Yesterday I took the time to do my drone. I read many articles about compass errors. And I decided that my compass is magnetized. In the local service, my compass is demagnetized special device. Called a Cfixer. And everything became good, there are no problems.
Reactions: Bobert1850
New Threads
NDS
