Hi, I am unable to calibrate the compass in Litchi, when i go into the menu and press calibrate nothing happens. Di i have to calibrate the compass in DJI app and then swap over to Litchi. ( just learning). Thanks.
Mike ... you'd be better off just getting a good compass calibration and sticking with it rather than unnecessarily recalibrating and introducing the risk of a bad calibration.Hi, I am unable to calibrate the compass in Litchi, when i go into the menu and press calibrate nothing happens. Di i have to calibrate the compass in DJI app and then swap over to Litchi. ( just learning). Thanks.
Ok, Will give that a try. CheersWhen you hit the compass calibration in litchi you would have seen the AC status lights turn yellow. The AC is then ready for your compass calibration chicken dance.
If your more comfortable with the App prompting you what to do calibrate in the GO app until you are familiar with the routine.
You don't need to calibrate before every flight. Get a known good calibration and stick with it unless flying a reasonable distance from where the calibration was done.
Hi again, really sorry about this. I turn on the P4, it urn on the remote controller, i turn on my I Pad and turn on the Lithci app, i then go to the settings on the Litchi app and scroll down to calibrate, the lights on the Ac are already flashing yellow ant the battery side and when i press the calibrate button nothing else happens, it does not ask me to do anything or alter the lights on the AC. I am obviously doing some thin wrong but as a newbie i don't know what it is.I got the app about 10 days ago and not been able to use it yet as still a bit wary if the compass is not calibrated. Thanks for your help and patience. MikeOk, Will give that a try. Cheers
And again. i am trying this at home without the props on but have tried it out side with no luck, i am now getting the message up on Litchi saying calibrate the compass and listen to the messages to carry on, no message and no diagram or notification for doing the calibration dance. Not got a lot of hair left now. Cheers again. MikeHi again, really sorry about this. I turn on the P4, it urn on the remote controller, i turn on my I Pad and turn on the Lithci app, i then go to the settings on the Litchi app and scroll down to calibrate, the lights on the Ac are already flashing yellow ant the battery side and when i press the calibrate button nothing else happens, it does not ask me to do anything or alter the lights on the AC. I am obviously doing some thin wrong but as a newbie i don't know what it is.I got the app about 10 days ago and not been able to use it yet as still a bit wary if the compass is not calibrated. Thanks for your help and patience. Mike
Cheers again.I will let you know how i do when i can next fly. Cheers MikeMike I suggested you calibrate in the GO app because it does give you the instructional pictures.
Litchi just puts your bird in calibrate mode. The same as flicking the mode switch backwards and forwards five times (I think it is 5). It would be st least 50 flights since I have thought about calibrating the compass.
If the calibration failed you would have a flashing red on the boom lights.
Seems you are good to go....
Thanks for another helpfull reply. Once i get out again i will be able to bombard you with other questions. I printed out the 35 Pages for the Lichi app but it does not tell you a great lot about any problems. Cheers again Drone King.If youve been trying inside, could it be magnetic interference? Usually Litchi tells you that, but seeming as it works when outside that could be why?
Yes and yesSo if I calibrate with Go then switch it to Litchi does Litchi know it is calibrated, does the home point show up on the Litchi screen. Thanks again. Mike
