compass calibrate before every flight?
ive been compass calibrating before every flight just incase. this wont damage the phantom in anyway will it?
cheers
No, but there's really no need. I only do a re-calibration if the craft flies strangely or if I move a significant distance from where I last flew (like 100s of km)
Is one not better re-calibrating before it flies strangely? I do it every time. I'd rather be safe than sorry seeing my investment do something untoward that might be challenging to recovery from or worse.
Sent from Samsung S4 via Tapatalk
+1 - not every flight but I do observe the time sats link and a quick hover on each flight to see how stable it is. You can usually spot strange anomolies pretty quickly. I do it if I know I'm in new area or long distance from last flight.
Only ever done a compass calibration 4 times.
1) When I first got it
2) When I added the Zenmuse and Gopro
3) When added the Fatshark, GPS tracker and Flytrex
4) When I upgraded to v3
It flies great and is super stable. I see no point in calibrating every time. More chance of getting a bad calibration if doing it every time. YMMV but thats what I do.
It could be a risk if you calibrate in a less than ideal area or in a haphazard manner. A bad calibration will usually end in tears. Save it for when you can do it properly.
I'VE gone by the rule new location then calibrate , but sometimes in the same place , if the lights don't go green , do the dance .
This is my thinking, too.
I used to do it every flight, but I started to get some strange flight behavior and it was due to me calibrating in a bad spot. I check things out in the P2 Assistant every 2-3 flights now and make sure my Mod value is within spec. As long as it is, I don't touch anything.
Flew today in a brand new spot, taking off from asphalt and flying in between some buildings and I know if I had calibrated there, it would have gone haywire.
Fink
cgarner1
