Color Correcting and Grading your P3 Footage V2
Discussion in 'Pro/Adv Discussion' started by fhagan02, Sep 6, 2015.
  1. fhagan02
    A closer look at what "the scopes" are for when color correcting and grading your P3 footage
    #1 fhagan02, Sep 6, 2015
    Jogle, hit-n-run, Mike Mauk and 11 others like this.
  2. 2nd2non
    Orange County, California
    As usual, great tutorial. Much better than ones I've seen and learned from on YouTube.
    I use to adjust my composite RGB curves the same way, but read it should be more like an 'S' versus 'Z'. Then adjust individual colors like 'Z'. Any perspective? My log shots tend to be flatter than your examples using same camera settings. As such 'S' adjustments to highs and lows seems less extreme than 'Z', although not all the time.... I guess I answered my own question...it depends...
    Btw- hope DJI takes care of you with your P3 replacement
  3. 4wd
    4wd
    North York Moors
    I like the grad application technique, however I find using the overlay mode makes the lower part of the frame brighter? - (unless I missed something!)
    If you use darken mode it seems to only act on the brighter area (sky mostly)
    You can also make an ND grad for bright cloud layer days to bring back some definition without making it blue.
    The Gaussian Blur effect looks pretty good, it's very like making an Orton Effect in stills.
    I do find it seems to greatly increase the rendering time when you add these adjustment layers though.
  4. jhoke
    Amazing Tutorial - Thank you so much for sharing this!
    I'm primarily an amateur still photographer, and grok a lot of what you are describing when i translate it into photoshop or on1 processes ... do you have or know of a good getting started with Premier ...
    thanks again - and my fingers are crossed that DJI gets you back in the air
  5. Reuben
    Brilliant so informative
  6. fhagan02
    Hmmmm. Make sure you have the graduated layer set to "overlay" under "opacity". It shouldn't be making the bottom brighter.
    kSilva likes this.
  7. fhagan02
    That was funny.:DI was thinking, "I think he's answering his own question".... and then I read you last bit, "I guess I answered my own question...it depends.." Made me laugh. Thanks for your kind words.
    #7 fhagan02, Sep 7, 2015
  8. phuocsandiego
    San Diego, CA
    Frederick... awesome tutorial, as always. I'm sad to read about your P3 in the other post. It seems like it's a total compass error and I hope DJI takes care of you. Keep up the good work in the mean time! We all benefit from it.
  9. Soaring Video
    Fantastic tutorial. I love the sky overlay and I'm not very good with Photoshop. Is there any chance you could post a link to download the one you've created?
  10. fhagan02
    It's a big file for uploading. But it's easy to create....
    • In Photoshop select create new document
    • Set the file background as "transparent" and size it 3840 x 2160 pixels at 72dpi
    • Create a "blue" color
    • Use the graduated paint tool and drag from the top to the middle of the canvas to create the graduation.
    • Save as a .psd so the image doesn't flatten and the transparency stays in tact.
    You're done. Place the newly created file in Premiere Pro, Final Cut or DaVinci and you're all set.
  11. fhagan02
    Thanks for your kind words. I have more footage than I know what to do with. lol.
  12. mirrorimage
    Palo Alto, California
    I love your videos. Tell me do you film in 24fps? Is there any advantage to filming in 30fps and changing to 24 in post?
  13. fhagan02
    Thanks for the comment. Yes I film just about everything at 24fps. The only advantage to shooting at 30fps and editing in 24fps is if you reinterpret the 30p footage to 24 within Premiere Pro. That'll give you a slight slo-mo effect. I do this when filming in the 1080 60fps mode. 60fps reinterpreted to 23.97 (or 24fps) will give you beautiful slow motion.
  14. Soaring Video
    Thanks, Ill give it a go
  15. 4wd
    4wd
    North York Moors
    You can easily enough make a few different grads to suit different horizon levels.
    Once you've made one it's so easy you can just make one to suit.
    For example you might do a reddish one to enhance a sunset.
  16. swoopair
    Great video!
    I have one frustration though. I have a pc and I cannot seem to bring up the yc waveform no matter how many time I watch the video.
    I have the latest version of premiere.
    Any way that you can point me in the right direction?
  17. 4wd
    4wd
    North York Moors
    Do you mean you don't get the window at all?
    In my version 6.0 you open reference monitor from one of the tabs probably tools at the top of screen.
    Then you can select a whole range of options for it to display.
    There should be a wrench at the bottom, or a drop down top right.
    I hadn't used that before but was using the reference monitor for adjusting exposure and contrast.
    fhagan02 likes this.
  18. swoopair
    I can't seem to bring up the window at all. I don't know where/how to find it.
    I've opened the reference monitor, tapped the wrench, and this is what I got (see attached picture)
  19. swoopair
    I got it, finally. Thanks for your help, 4wd!
  20. 4wd
    4wd
    North York Moors
    Sorted this, I was using an existing PS grad which was blue to white rather than blue to transparent - from the simple selection.
    I made a new one based on the NDs which fade from black to nothing. (using blue to nothing)
Similar Threads - Color Correcting Grading Forum Date
First attempt at color correcting/editing Photos and Video Apr 7, 2016
Color correcting tutorial using subscriber submissions Pro/Adv Discussion Feb 2, 2016
Still having trouble with correcting color for video. Tips and Tricks? Standard/4k Discussion Jan 12, 2016
Sunset color gone??? Phantom 4 Pro Help Today at 11:34 AM
Advanced Video/Picture are dull in color Phantom 3 Help Yesterday at 3:22 PM
