Cold weather?
Discussion in 'Phantom 1 Help' started by sean7488, Jan 29, 2015.
  1. sean7488
    Hello all
    So I tried flying my Phantom 1 yesterday. It was about 28 degrees F outside. When I tried to increase altitude, it wouldn't go up past about 100 feet. Is this because of the cold or something with the Phantom? I never had this problem before and I never tried flying in the cold before so I'm not sure.
  2. kitari
    Paris, TN
    I've flown in cold weather all winter (temps as low as 17F) just fine. The only bad thing about cold weather flights I've noticed is shorter flight times.
  3. Monte55
    Raymore Missouri
    You might check your limits in assistant software
  4. sean7488
    Any ideas as to why my altitude wouldn't increase than?
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    sean7488, check that the "Max Height" is not set to 100 ft in the Phantom Assistant application.
  6. sean7488
    Mine was set at the default, 2000m
  7. Prophecies
    Montreal, Canada
    The cold has nothing to do with it. I must have flown around 100+ meters up in -30°C (-22°F) and I've had no issues whatsoever.
  8. sean7488
    Any other insights? I still haven't figured this out and it's not max height.
  9. PhantomFanatic
    USA, GA
    I don't have a clue, sorry. Is it still under warranty?
Similar Threads - Cold weather Forum Date
"Aircraft disconnected"/RC loses connection in cold weather. Phantom 4 Pro Help Feb 28, 2017
Hi from ont canada cold weather flyer Introductions Feb 11, 2017
Phantom 4 Pro + lost control in cold weather Phantom 4 Pro Help Feb 4, 2017
Tip for Keeping your batteries warm for cold-weather flying Phantom 4 Discussion Jan 31, 2017
Phantom 4P Propeller Icing In Cold Foggy Weather General Discussion Jan 17, 2017
