Cloverleaf antenna on TX end only?
Discussion in 'Photos and Video' started by Eos630, Feb 7, 2014.
  1. Eos630
    I bought the 5" DVR monitor/receiver as seen at Dronefly. It uses a single dipole antenna and the cloverleaf type will not fit. I have a cloverleaf which fits my AVL58.
    Any thoughts on using a cloverleaf on the TX end only?
  2. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    I believe that is a -3dB loss over using two cloverleaf antennas. Not the end of the world but 3dB will be a noticeable difference if you plan on covering a lot of ground.
  3. rcphoto
    In the 5" monitor from Dronefly, it has a little reddish- white cable that allows you to plug in the RX end of the cloverleaf. If you kept all the accessories, it is in there! Mine gave me about an extra 200 feet!
  4. Eos630
    Oh man, how dumb of me. It was in there. I thought they'd use an adapter, not a cable to do it. But after scouring the internet, I found that nobody makes that adapter (as one piece.) It does look a little goofy with the cable dangling out of it like that, but thank you very much for helping and I look forward to the extra 200'.
Similar Threads - Cloverleaf antenna end Forum Date
AVL58 Cloverleaf Antenna Bendable? FPV (First Person View) Sep 16, 2014
If I mount a right handed polarized cloverleaf antenna on the bottom of my phantom 3 Standard Standard/4k Discussion Apr 21, 2017
Can cloverleaf antenna be used for WIFI? FPV (First Person View) Jul 20, 2016
Cloverleaf Receiver Antenna FC40 Phantom 1 Discussion May 13, 2016
How far can i get FPV signal with 250MW transmitter with cloverleaf antennas? Phantom 2 Discussion May 2, 2016
