Close Call
Discussion in 'General Discussion' started by drifter, Oct 29, 2014.
  1. drifter
    Hi all need some advice.
    I was on my 4th flight today and the bird kept going straight up. It would not respond to the controller so I turned off the controller to activate the fail safe mode. Fail safe mode worked but the bird descended fast on the last couple feet making for a rough landing which caused the bird to tip on its side before I could shut it down. Thankfully I have prop guards.
    So…I flew another flight with a new battery and everything worked without a problem. My question is should I recalibrate everything including the IMU or do you think it was just a fluke problem?
  2. paulajayne
    Bocking - England
    Did you have a good GPS lock? Did you calibrate the compass?
  3. drifter
    yes and all batteries were fully charged.
  4. IflyinWY
    Where the deer and the antelope play
    Could the throttle have been pushed up while you plugged in your battery?
  5. drifter
    No, but I'm going to update my firmware so I'll be doing the calibration again anyways...I'll keep you posted if it happens again.
  6. drifter
    Just for future reference what happens to the controller stick control if GPS isn’t fully locked in before a flight while in Phantom/GPS mode?
  7. Peter Patricelli
    Eugene, OR USA
    One possibility.....of flying directly overhead and holding the controller vertical.....so the antenna is pointing straight up.....there can be a dead zone where you lose control. So if the bird is directly overhead and starts climbing....it could keep right on going for awhile. The answer to the dead zone effect is to turn the controller/antenna horizontal. Antennas, both Tx and Rx transmit and receive best perpendicular to their long axis.
    That may or may not have been your problem but one thing to think about.
  8. N017RW
    Palm Beach Co.- FL
    With regards to the emphasized sentence above...
    Antenna's work best when their polarization axis are parallel to each other not perpendicular.
Similar Threads - Close Call Forum Date
Close Call? Do you have a close call video or story you would like to share? Photos and Video Aug 29, 2017
And yet another drone close call News Aug 17, 2017
Another drone close call News Aug 17, 2017
Close call Standard Jul 15, 2017
Had a close call this evening Pro/Adv Discussion Jun 28, 2017
