Classic newbie error, dead motor :(
I whilst switching out the prop guards I accidentally picked up one of the longer screws (only one) and turned it into the motor now it stutters.
Is it a right off now presumably ?
Yep that motor is probably bolloxed and needs swapping but the good thing is they are not too expensive :)
Does the screw tend to damage the magnet or the windings? If the magnet them maybe I can simply replace the can without getting my soldering iron out
Is it a pain in the arse job? I won't be flying tomorrow now it would seem :(
A new DJI motor is about $28.00US
You need to lay it on its back & remove the 3 hex bolts on each arm with a 2mm Allen key, then the single Phillips screw at the very tip of each arm. 16 screws altogether.
Do not undo the 4 that hold the motors on by mistake. Flip it back over & remove the top but be careful when you take the top cover off as the GPS cable is attched underneath, reach in & disconnect it. Then turn it on its back again.
You'll have to unsolder the red/yellow/black wires of the dud motor, making a note of where each color wire goes. Turn it over once again then remove the 4 screws holding the dud motor in. Replace it with the new motor making sure it is the correct one. They are marked as CW & CCW indicating the direction of rotation because 2 have L/H threads & 2 have R/H threads.
Should only take 15mins. Just be careful not to have the soldering iron too hot or you may damage the circuit board.
