Checking HD signal.
The answer to this question maybe on this site already, but I am having major problems getting around the site and constantly getting locked out or not getting into the site. so I will try to get a quick question in before i get locked out... Prior to take off should we check and adjust the HD channel or once we find a good one stick with it. I did notice today that while flying in an area that I have flown in before the picture started to scroll again on my iPad which I believe is a signal problem.
Unless you unlocked all 32 channels, it's usually best to allow your Phantom to auto select the best channel.
Which model iPad are you using?
Reactions: WetDog
I started flying with it on auto and it was really bad, so I changed it to custom and picked the better signal. I use the iPad mini 2
wkflysaphan4
