That's the same issue I was having. Is re-linking an option in the app somewhere? I must have missed it. Thanks!I noticed I was getting an "Overall Status" message that Aircraft requires update. Seen that before the last time I installed the 1.6 FW. So I relinked my RC and so far the RTH Height is now staying put.
Haven't noticed, I set it once and haven't looked since. I'll check tonight or tomorrow.Blade as commented on this subject on another thread before stating like bbfpv did that it is a bug in the app software, but he did not mention that a relink would fix it and he is pretty clued up on these subjects to say the least. Let us know how you get on anyway with your next flights.
bbfpv what are your thoughts on this, i was going to say have you tried a relink but i think your on a nvidia are you so you wont have this problem.
Again, the parameter is stored bird-side, so yes, it survives power cycles. It's a glitch in the app displaying the wrong value.Yeah, I wonder if it survives power-cycles.
If the 0m were real, yes.That could be scary ! I normally stop flying when I hit RTH
Which is why mine V+ is set to 200'
Lets hope they fix that one quickly. So at zero I assume it stays at current elevation and attempts to return home.?
ok just checked this out as I always fly out of my yard and power lines between me and free airIf the 0m were real, yes.
Has that been fixed on new firmware of is the problem in the app ? (android or iOS ?)yes.... it's a known bug in the software. the bird remembers what you put in last.
Of course you can also set a custom RTH height each flight to suit your flying environment rather than making a global setting.
It's easy to fly to a position you are comfortable with and set a new Home Point up in the air to provide a safe clearance above trees etc.
Here's what the manual says ....So if I take off to the highest point I want to fly and then press Home point it will store this point. If the signal is lost it will ascend to this height if RTH or continue at the height if above this?
