Cheap Lens Cover
These ACE Hardware Leg Tips fit perfectly. Only issue is that at original size they stick out quite so the unit will not fit back in the original box. I cut mine back to about 3/8" and did have to thin out the inner wall with a Dremel tool a bit as the tip is thicker at the bottom.
Reactions: DMac
Discovered another use for these caps. Out of the box they have the perfect grip for removing the UV filter.
jrl
