Cheap gimbals.
Discussion in 'General Discussion' started by Ozzyguy, Jan 26, 2014.
  1. Ozzyguy
    Townsville,Australia.
    Ok so I've seen a few cheap gimbals on EBay and I nee to know do I have to buy one with its controller on the gimbal. Surely I can just connect the two cables that control the motors to the Naza and buy one without its own dedicated controller couldn't I?
  2. Ozzyguy
    Any help would be appreciated
  3. FatKevinSmith
    The Gimbal controller board is what tells the motors what they need to be doing. There's no connection between that board and your Phantom except for power and perhaps the tilt control if you have a 7th channel. I think the Zenmuse system works off the NAZA M but don't know if you can retrofit a generic gimbal to work with it.
  4. Ozzyguy
    Ok thanks. I was thinking of buying a gimbal and plugging it straight into the naza. Ill spring the extra for one with a control board.
  5. Ozzyguy
    I was under the impressions you could just plug straight into the Naza.
  6. Ozzyguy
    Has anyone tried a direct connection to the Naza?
  7. krousso11
    Los Angeles, CA
    This is the one I purchased...I am really liking it...smooth videos and pitch control works! Also these guys were very helpful when I messed with the firmware and screwed it up! They sent me over the debugged parameters and had the gimbal working again in no time at all!
    http://www.ebay.com/itm/Assembled-RTF-G ... RTM1562570
    Hope this helps!
  8. Ozzyguy
    Thank you but what I actually want to know is do I need to buy a control board with the gimbal. I want to save weight buy not using one and plugging pitch and roll into the Naza. Surely the gyro within the Naza is sufficient.
  9. Ozzyguy
Similar Threads - Cheap gimbals Forum Date
Cheap gimbals - any plug and play? Phantom 2 Discussion Sep 12, 2014
Inexpensive (cheap) gimbals--any good? Photos and Video Apr 21, 2014
cheap gimbals on ebay questions General Discussion Feb 21, 2014
is DJI really giving more features to cheaper drones? Phantom 4 Pro Discussion Yesterday at 6:40 PM
Cheap drop system... General Discussion Jan 17, 2018
