Cheap gimbal big problems
Discussion in 'Phantom 1 Discussion' started by carter840, Sep 7, 2014.
  1. carter840
    So I got the cheap gimbal from by luck sell that many others have had success with. Sadly I seem to have messed something up. I have everything wired, but when I put a battery in the gimbal just shakes like crazy. It doesn't get close to level it just does nonsense. I have tried using Naza and activating the gimbal but those changes don't seem to do anything to the gimbal. Any advice would be really helpful, I have watched a bunch of online videos, but none of those help diagnose such an issue.
  2. 4wd
    4wd
    North York Moors
    Firstly be aware you must have the camera on and it needs to be balanced - trial and error for exact position.
    Sometimes rotating the camera cradle a full turn seems to settle it
    You'll probably never make much of it, I found it reduced flight times horribly on my P1 and made the phantom vibrate intermittently, to the extent it felt unsafe.
  3. carter840
    I appreciate what you're saying, but at this point I would like to at least try to just make this thing work. It seems like others have done a lot better than me so I am just hoping to get it working in a similar capacity. Do you have any links that detail balancing or how to setup this type of gimbal?
  4. erlend m b
    Make shure your gimbal is balanced (with the gopro) and level and moves freely before you plug the battery in. If it doesnt work, do like the guy above said.
    If you still have the problem, try switching the wires to the motors on the circuit board.
    If that doesnt work, try doing a calibration in the software.
Similar Threads - Cheap gimbal big Forum Date
Standard will the cheap gimbal from China still work for live streaming? Phantom 3 Help Jan 30, 2017
install help for cheap chinese gimbal and cheap gopro knockoff Phantom 2 Discussion Dec 28, 2016
cheap hack - solution - areal shot w gimbal and GoPro? General Discussion Sep 29, 2016
Australia.... Cheap gimbal lock Standard/4k Discussion Feb 19, 2016
Cheap gimbal problems - have I wired this completely wrong? Phantom 2 Mods Feb 13, 2016
