Charging Question
Discussion in 'Phantom 1 Help' started by wareaglenc, May 9, 2014.
  1. wareaglenc
    I have a Phantom 1. BC20-4 Balance Charger. Settings liPo and 3A. When I connect the phantom battery for charging, the 3S. Light only flashes and the battery doesn't seem to charge. Any suggestion?
    Thanks,
    Mark
  2. Ozzyguy
    Townsville,Australia.
    Use a volt meter and check the voltage. Then post up what you find. It may be that the battery voltage is to low
  3. tanasit
    If this is your first time using the charger, see the manual below:
    http://download.dji-innovations.com/dow ... uction.pdf
    It looks like your pack is almost full and the flashing red led indicating that the charger is balancing the pack. Nothing wrong.
    Use the pack and try again.
  4. cjaviert
    If the flash colors are green and red it means its almost charge just wait 20 minutes or less and it will be green, but when the red light is still it means its not charged and you need to wait at least 1 hour before red and green flashing.
Similar Threads - Charging Question Forum Date
Phantom 4 RC not fully charging question Phantom 4 Discussion Wednesday at 4:15 PM
Battery charging hub question Pro/Adv Discussion Jul 17, 2017
Quick P3s charging question Standard/4k Discussion Jun 3, 2017
Charging hub questions Phantom 4 Discussion May 22, 2017
???Question About Phantom 3 LiPo Battery Balance Charging/Discharging??? Standard/4k Discussion Feb 8, 2017
