Charge p3 battery with P2 charger?
Discussion in 'Pro/Adv Discussion' started by Pettermannen, Aug 3, 2015.
  1. Pettermannen
    Hi! Need help regarding charging. Is it possible to charge a p3 battery with a p2 charger. Also have anybody tested the cheap P3 car charger on ebay for about 10 dollars. Please give me a link of regular chargers and car chargers that in your opinion will work.
    Best regards
    Petter
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    No.
  3. RoyVa
    Virginia
    Don't even try... Different completely. Want to charge in your car. It's better to use the 110 charger on an inverter. The inverters can be picked up at a less cost them the car charger. Pick up an inverter that is 200 watts or more.
    #3 RoyVa, Aug 3, 2015
  4. J.James
    Upstate NY
    The p2 charger only puts out a tiny bit over 12.6 volts while the p3 battery needs just shy of 18volts so it will not work. and any of the car type chargers will not work unless its got some sort of step up converter in to to be able to raise the cars 12-14.8 volts up to about 18 volts to be able to charge a p3 battery.
    Do as others suggested and get an inverter. You will be much happier. and you can also use the inverter to plug other stuff in to as well. Like if you want to charge your tablet or what not.
Similar Threads - Charge battery charger Forum Date
How to charge P4 battery without charger Phantom 4 Help Dec 30, 2017
Powerextra battery charger for Phantom 4 series... Phantom 4 Pro Discussion Dec 25, 2017
Use of Telesin P3 Battery discharger Pro/Adv Discussion Dec 1, 2017
Where to get the AC power cable for the battery charger? Phantom 4 Help Nov 21, 2017
Battery Charger Review Photos and Video Oct 6, 2017
