Change to More Natural Tilt Speed and Ramp with Futaba T8J?
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by adanac, Aug 4, 2014.
  1. adanac
    NYC
    Is there a way to make the H3-3D less servo-like and more "organic?" Perhaps with my TX, which is a Futaba 8J?
  2. IrishSights
    Bangor, Northern Ireland, UK
    Re: Change to More Natural Tilt Speed and Ramp?
    Can you not use the gimbal control in the firmware?
  3. noiseboy72
    Lincs, UK
    Set the gain to 1 and you will find you get very smooth motion and quite a gentle ramp into movement.
    To help this even more, I fitted a full sized pot and knob, and calibrated it for full travel. This gives me very precise control.
  4. IrishSights
    Ive done the same with a replacement linear slider pot set to 2 in the firmware. Gives beautiful cinematic tilts.
  5. adanac
    NYC
    You installed a pot and knob to your T8J?
  6. IrishSights
    No, sorry, its on the stock controller.
  7. adanac
    NYC
    It's my fault for not being clear. This thread is about using a T8J, not a stock controller.
  8. OI Photography
    Clarksville, TN
    Re: Change to More Natural Tilt Speed and Ramp with Futaba T
    I don't know how it's done on that Futaba model, but most aftermarket controllers in that class allow you to adjust the output rate of the pot(s).
    I have mine slowed down a good bit that way and I love the motion it produces.
  9. noiseboy72
    Lincs, UK
    I don't think the controller matters, as the gains are set on the 'bird. The lower the gains, the slower the response. 1 or 2 gives a really smooth movement.
    There is nothing to stop you fitting a new pot to your TX. The procedure is the same. You can even replace some switches with pots as well, but this requires a little more knowledge about which switches directly control channels and which are system assignable. Not done it on a new Futaba, but did mod an old one years ago.
  10. adanac
    NYC
    I see no place in the software for controlling the gimbal tilt gain. I'm on V2.0.
Similar Threads - Change More Natural Forum Date
WHATS HAPPENED, Nothing changed Standard Yesterday at 5:06 PM
Why P4P video size changed between recordings?! Phantom 4 Pro Help Thursday at 2:05 AM
Phantom 4 price changed. SOLD Classifieds Jan 14, 2018
altitude changed? Phantom 4 Pro Discussion Dec 28, 2017
This will change the way you color your drone footage Photos and Video Dec 20, 2017
