Change to FCC mode from CE
Discussion in 'Standard/4k Discussion' started by Skippy[M], Apr 10, 2016.
  1. Skippy[M]
    Hello!
    Got a Phantom 3 Standard. I want to change mode. From CE to FCC. How to do it?
  2. N017RW
    Palm Beach Co.- FL
    This is no longer user adjustable. It is determined by your global location as determined by the aircraft's GPS coordinates.
    Look into the numerous methods to improve range from Windsurfers to directional antennas and/or amplifiers. However the latter requires a license to operate legally in the US.
  3. Skippy[M]
    Oh I see. I live in sweden so I will not be able to change to FCC mode??
  4. Air Ontario
    U.S./ Canada
    I would imagine the difference in in hardware. One is built with less transmission power and certified under CE. The other has hardware that allows more signal strength to be transmitted and is certified FCC.
    Just my guess.
  5. N017RW
    Palm Beach Co.- FL
    Correct.
    (Unless someone hacks the code in the future but that is just for conversations sake.)
    Folks have been trying for just about two years now to override this and other software imposed limitations with no luck. No reason to believe it will change anytime soon.
  6. N017RW
    Palm Beach Co.- FL
    These radio parameters and adjustments are easily achieved with software.
    Your cellphone does it many, many, times per second.
  7. Air Ontario
    U.S./ Canada
    I do hear rumors about attempts to hack drone transmissions so that may be a concern and even to the point of modified ranges I suppose.
    Funny I remember the CB days when many were attempting to boost wattage.
  8. JamesG2571
    I've heard that the mode changes depending on your location so if you took your drone to an FCC country it would automatically change to FCC and vice versa
  9. N017RW
    Palm Beach Co.- FL
    That is a fact.
Similar Threads - Change FCC mode Forum Date
Change from CE to FCC power Pro/Adv Discussion Jan 17, 2016
Standard Grainy video when light changes Phantom 3 Help Wednesday at 2:06 PM
Litchi changes headings before reaching waypoint? General Discussion Tuesday at 8:12 PM
Can I change settings for phone video during flight? Standard/4k Discussion Saturday at 10:15 PM
Are All P4, P4A & P4P Accessories Interchangeable? Phantom 4 Discussion Saturday at 4:30 PM
