CE/FCC on P3?
Discussion in 'Pro/Adv Discussion' started by storm_333, Aug 6, 2015.
  1. storm_333
    Sorry if this has been answered before. I've had a Phantom 2 Vision for a year and I'm thinking of upgrading to the P3 because of it's much longer range. Am I right, though, in thinking that models in Europe have less range because CE regulations mean they must have a lower output? What is a typical sort of flight distance of an unmodified craft in Europe? Apart from the better camera there wouldn't be much point in upgrading if the range isn't MUCH greater than the P2. Thanks in advance!
  2. 4wd
    4wd
    North York Moors
    In theory they have a bit less power.
    It's supposed to know to use the lower power setting dependant on your location, so if you took it outside the EU the higher power would kick in automatically.
    In practice most users are not finding much difference in range.
    It's more dependant on local conditions.
    In ideal clear area with line of sight contact you should still get very close to 2km and further than that is possible.
  3. robinb
    i can get 2km and still full power.
  4. Glimo
Similar Threads - FCC Forum Date
Mavid Dji.configs FCC mode working with P4P? Phantom 4 Pro Discussion Aug 3, 2017
FCC & FAA Rules and Regulations May 28, 2017
It's official, The DJI Phantom 4 Advanced has FCC clearance! News Apr 12, 2017
Easiest way to activate FCC (Advanced) Pro/Adv Discussion Apr 12, 2017
REQ: Phantom4pro FCC ID#, TIA Phantom 4 Pro Discussion Feb 14, 2017
