Be advised if you are using the Naza V2- GPS your machine will take-off with no prior warning - which could result in an accident or serious injury.
Problem: DJi’s new “Non-Signal” firmware which monitors the receiver for a “No Signal” status them automatically engages failsafe has no priority to lock out this feature while on the ground.
Event: Pilot engages and starts the motors – if the pilot does not move the cyclic yaw or throttle sticks for a short period of time - the Naza instantly enters “fail-Safe” mode and in a few seconds goes to full throttle in an attempt to reach failsafe altitude therefore causing the pilot to think the machine is in a fly-away state.
My Event: I set the machine on the runway spooled up the motors, after a few seconds, I walked over to my FPV monitor to check the readout battery voltage - as I began to walk back to the machine, the multi blasted off the ground – As I held low throttle in hopes of reducing the accent - I switched to failsafe with no results - next I flipped to ATTI to dump the GPS and my machine went to low throttle tumbled out of the sky, unknowingly, my 40+ years of reflex instantly added throttle in time to prevent the motors from shutting down and it nearly hit my truck and Linda as it sped back up to the ground.
I recommend that anyone using this Naza be aware of this error and take precautions when on the ground and spooling up the motors – remember if your in GPS mode you’ll have to move to ATTI to dump the fail-safe routine already started. DJI needs to address his problem with a update to prevent fail-safe engagement while the machine is on the ground.
Fly Safe!
Mike Mas
Bench test of error video attached
http://youtu.be/03VRozck72c
Fly Safe!
Mike Mas
