Carrying Case
Cambridgeshire
This is my carrying case for my Phantom
After looking at the very expensive PELI cases I opted for a very nice case from Maplin @ £49.95 it's a very good alternative, and it comes with the foam ready for you to pick and pluck the pre cut squares out.
Is this the one? http://www.maplin.co.uk/large-high-impa ... dxh-228650
It looks like it is a tight squeeze! I want a case that can snugly hold and protect the Phantom without having to remove the props or landing gear.
Also, it says in the description that this one has pre-cut foam, that makes me wonder if I am looking at the wrong listing.
Anyway, it looks like a good one, at a considerably lower price!
Hi Sac D
It is that one :)
The pre cuts in the foam are small squares that you pull out of the sheets to make the compartments you want.
It is tight but you do not have to take the props or landing gear off for it to fit, if you centre the Phantom it is a good fit.
and it is much cheeper than some of the others on the market.
cokersean20
