Carbon Fiber Composite Adjustable Landing Gear
Discussion in 'Phantom 2 Vision Discussion' started by Drone-Outlaw, Apr 3, 2014.
  1. Drone-Outlaw
    United States,Houston, Tx
    New item on Ebay. Item # 90220366
    ★Height 12.5- 14cm adjustable
    ★Weight 108g
    Cost shipped $70ish
    http:youtu.be/3tEIssooo_g
    The above a short video of the item, however I can't seem to get it loaded properly.... :oops: anyone???
    Moose
  2. BMEWS
    Cambridgeshire UK
    put in the full URL minus the s and you should be good to go. Not sure i'd bother over the stock set. Now if they're retractable? Maybe. (I've found one video of retractable skids for a Phantom), but not sure i'd go for that particular set up.
    hope this helps
    Bmews
    [youtube]http://www.youtube.com/watch?v=3tEIssooo_g[/youtube]
  3. Drone-Outlaw
    Your awesome Bmews! Thank you so much!
    Moose
  4. FlyingFox
    Cheshire UK
    Anyone know the weight of the stock skids to compare, these maybe better for anyone purchasing a gimble as I have one on order and from the videos on you tube whilst the copter is on the ground you cant point the camera down as it will touch the floor.
  5. dataway
    Southern California
    Would the Carbon Fiber cause issues with the electronics in anyway, especially the compass since it is mounted to the skid?
  6. Hiway
    I have these skids... they are heavy, and they are impractical if you plan on using a gimbal.
    I used parts from this particular set to fabricate my retracts.
    To address the compass concerns- it will not affect the compass, and it does not affect the electronics- it does offer a very stable landing platform, but it is truly overkill in my opinion as it has so much extra material than needed- it is over-engineered.
Similar Threads - Carbon Fiber Composite Forum Date
testing 9450 carbon fiber props (Composite Hub, Black with Yellow Stripes) Pro/Adv Discussion Feb 4, 2016
9450 Carbon Fiber Reinforced Self-tightening Propellers (Composite Hub, Black with Yellow Stripes) Pro/Adv Discussion Jul 21, 2015
9450 Carbon Fiber Reinforced Self-tightening Propellers (Composite Hub, Black with Yellow Stripes) Pro/Adv Discussion Jul 15, 2015
Carbon fiber shell? Phantom 4 Discussion Friday at 2:44 PM
P3P and Three-Bladed Carbon Fiber props... General Discussion May 15, 2017
