Updated recent Vision app. and now I can't change RTH altitude. App shows "Set altitude failed". Attempted altitude height 75'. I am connected to Phantom. Worked fine before update.
Anyone else have this problem?
I had the same issue. While in flight I must have tapped the altitude on the bottom of the display and got a pop up that asked if I wanted to set the current altitude as RTH altitude or manually input your own. I personally have mine set at 120ft which gives me a piece of mind that I am higher that any surrounding trees, power lines, etc. I hope this works for you.
You should set it up in the Phantom app while the device is connected to your computer. That's the way I change mine. Get to know the height of the objects in your area, so you can set it higher.
Thanks for the replies. After some deliberation I think my problem may be due to me not updating to latest Phantom firmware. Pray for me when I update the firmware. My Phantom has been flawless, I hope it remains that way after update.
