Advanced Can't get lens cover off!
Discussion in 'Phantom 3 Help' started by SnoozeDoggyDog, Jul 15, 2015.
  1. SnoozeDoggyDog
    Hi,
    Does anyone have a tip for unscrewing the lens cover from a P3A please? I've applied as much finger pressure as I can and it isn't budging. I have some pipe/mole grips that I've thought about using but I can see that method going terribly wrong!
    Phil
  2. TAZ
    TAZ
    It actually takes very little pressure. I was convinced mine was stuck...as I couldn't remove it with my fingers no matter how hard I tried. Read a few threads that suggested just wrapping a rubber band around it..and using even pressure. Still unconvinced. But didn't have any rubber bands handy, so I grabbed one of those rubber garlic peelers I had handy in my kitchen (fits very conveniently over the end)... With very little pressure, it came right off.
    I'd imagine rubber kitchen gloves, a rubber band, (or in my case a garlic peeler) would all work equally well.
    SnoozeDoggyDog likes this.
  3. SnoozeDoggyDog
    Ah, OK. Thanks. I'll give that a go ...
    Thank you for replying.
    TAZ likes this.
  4. SnoozeDoggyDog
    Worked a treat. I threw a rubber glove over the lens twisted and hey pesto! Off easy as you like. Less is certainly more. Brilliant. Double likes.
    Thank you
    J.James likes this.
  5. craig4855
    I use a latex glove - hospital type. Provides a great grip, with very little pressure
  6. SnoozeDoggyDog
    And dual use ..... Cough
    snowghost likes this.
  7. craig4855
    Please do not use "found" gloves :)
    bobmyers likes this.
  8. Trumple
    UK
    For anyone else having issues - I found curling my index finger underneath the barrel with my thumb at the top of the barrel helped, so that twisting pressure was applied over a wider surface area, leading to less bending and easier unscrewing :)
  9. SnoozeDoggyDog
    Yup. Definitely less pressure over a greater area works a treat.
  10. SharpShooter
    Mackay, Queensland, Australia
    Well... there ya go !! I couldn't get the **** thing off no matter how hard i tried. I jumped onto the forum and read this thread and headed for the kitchen to find the rubber gloves. It still wouldn't come off. The next trick was oxy acetylene and some stillsons !! I kept gradually spacing my fingers around it with the rubber glove and off it came. Awesome !!
Similar Threads - Can't lens cover Forum Date
Can't get camera lens ring off ???? Pro/Adv Discussion Mar 23, 2016
P3A RC Cyan led fix and I can't enter in camera view Pro/Adv Discussion Sunday at 12:10 PM
Beeping loop after update failure. Can't update drone anymore Phantom 4 Help Sunday at 10:19 AM
Can't launch my DJI Go software Control (Go, Litchi, etc..) Jan 9, 2018
can't wait to get my Samsung Galaxy Tab S3 Phantom 4 Pro Discussion Dec 31, 2017
