Can't get intelligent flight modes to show
Discussion in 'Pro/Adv Discussion' started by wings1, Feb 17, 2016.
  1. wings1
    P3P flip switch to F and it shows F-GPS but the intelligent mode screen does not appear. Any help?
    Also, searched for this topic, but can never find specific threads. What are some tips to find a topic so I don't duplicate?
  2. Orion55
    what firmware do you have?
  3. Ed209
    Go under advanced settings in DJI Go and enable Multiple Flight Mode
    PJ Orlando likes this.
  4. Meta4
    Meta4 Moderator
    Staff Member
    Read the last two lines in this section of the manual and you'll see the most likely cause:
    [​IMG]
    MrMcfly likes this.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    wings1, you also need to take off and be at least 10m in the air before attempting to enable F-mode.
  6. tvckz
    TVC
    If you do not see any menu it is probably because of your ipad iphone whatever. I
    For example I have iPad 3 mini without cellular and Barometer & Altimeter - I do not see that intelligent menu either. If I use Samsung smartphone A5 - it works.
  7. Essex Thunder
    Fallston MD USA
    Mine wouldn't come on till I turned the GPS function on in my phone. My phone is what I use to fly with, through the DJI Go app
  8. MrMcfly
    Melbourne, FL
    Hmpf.... the manual.... who knew??:fearscream:
    Admittedly there's more stuff that has to be 'right' to engage intelligent flight mode, it makes it seem less intelligent than it is. Litchi is so much better at "intelligent flight".
  9. wings1
    Thanks all for the help!! Such a great forum for help. Always appreciated!!
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    So, did you figure it out?
  11. wings1
    Sorry. Not yet. Winds have been way to high the last few days. I'll get out tomorrow and check it out. Will update then.
  12. wings1
    IOC is and was on. Multiple flight mode on. Using iPhone 6plus so gps is good. Got to 40m and still couldn't get IOC screen.
    Any other direction?
  13. Air Ontario
    U.S./ Canada
    So when you flip PAF switch to F, you don't get the blue icon left of the mode indicator in the top taskbar?
  14. wings1
    I do not get any blue icons.
  15. wings1
    When I just flew and switched to Fmode the the controls acted like they were in course lock mode tho. Pushed stick to go forward and bird went backwards.
  16. MrMcfly
    Melbourne, FL
    What type of Pad/Tablet/Phone are you using?
  17. wings1
    iPhone 6 Plus. I've used multiple flight before with this phone and bird. So apparently I changed some setting. But I've done all the things on this thread.
  18. MrMcfly
    Melbourne, FL
    You might want to try deleting the Go App, and re-installing it. Fully shut down and restart the phone after removing the App. It's a long-shot, but it resolved
    an issue I had when I wouldn't get signal lock. Worth a shot if if you haven't tried it...
    Other thoughts... Shut all other apps down (iPhones never close an App when you're done with it, DAMHIK)
    Try using Airplane Mode??
    As you've mentioned, you may have adjusted a setting or installed something that's mucking up the works.
    Good luck!!
  19. Air Ontario
    U.S./ Canada
    Didnt read whole thread but did you verify multiple flight mode switch is toggled to the on position in the go app menu page?
  20. wings1
    I will try uninstalling and see what happens. That sounds like a good idea.
    I though if you went to airplane mode without wifi you could not use any intelligent modes?
Similar Threads - Can't intelligent flight Forum Date
Still can't get intelligent flight modes to work Standard/4k Discussion Jun 3, 2016
Can't get controller and bird to connect. Just updated. Any ideas? Pro/Adv Discussion Yesterday at 8:02 PM
Can't calibrate the compass Phantom 2 Vision + Discussion Yesterday at 3:28 PM
Can't go higher than 120 meters Phantom 4 Help Monday at 9:25 PM
[MAJOR PROBLEM] CPU Fully Loaded - Can't Fly General Discussion Aug 10, 2017
