Hey, thats nothing todo with connecting to the Phantom. Its an error downloading the google map. Had the same issue while back. Could be a few things... First check your laptop internet connection is connected and working. Start ground station using VPN mode. If you have the same problem still, try uninstalling, restarting laptop then reinstalling the google earth plugin. If that doesn't work it could be your firewall blocking the connection.
Can always start GS in offline mode to connect to P2 but will have no map, unless downloaded and saved for offline use. Otherwise GS just wont work, I think.
