Advanced Cant connect to litchi
Discussion in 'Phantom 3 Help' started by keevan, Aug 29, 2016.
  1. keevan
    Only connected to litchi 3 times after 1/2 hour fiddling each time. Any way to force connection when stays disconnected? I need some help and suggestions.
  2. ryantrax
    Xenia, Ohio
    I've had issues on my Samsung Galaxy Tab S2 with Litchi. In my case you can't have DJI Go installed in order for it to connect. Even if the DJI GO app is force closed Litchi won't connect. I hope Litchi fixes this soon. Give it a shot, if yours is similar to mine It will work after uninstalling DJI GO.
  3. keevan
    Thanks for the tip, Ryan. I will certainly give that a try ASAP.
  4. keevan
    I uninstalled DJI and icons disappeared but litchi still will not connect
  5. ryantrax
    Xenia, Ohio
    What type of tablet do you have? Have you restarted since uninstalling?
  6. keevan
    Success! Would not connect after uninstalling so as a last resort, I changed usb cable and BINGO, connected right away and flew 2 good missions. Was a short white cable that seemed OK for charging but nothing else.
  7. Thomas Cole
    I have Litchi on my phone and dji go on a separate tablet. No conflicts there! Tend to use Litchi as primary.
  8. Frank chrome
    Hi I just bought the galaxy s2, using it in the phantom 4 and it will not connect. I don't have the dgi go installed but this litchi wont connect. Does anyone have a solution for this.
  9. ryantrax
    Xenia, Ohio
    I had the same problem you have to add a second user on your Samsung tablet and only have DJI go installed on one of them and litchi installed on the other user
  10. Frank chrome
    Hi ryantrax. Not sure I understand. How do you add a second user? At the present all that is installed is litchi, dji go I Uninstalled it.
  11. ryantrax
    Xenia, Ohio
    Do you have the Galaxy tablet S2 or the phone? On the tablet you can add a second user.
  12. Frank chrome
    I have the galaxy S2
  13. ryantrax
    Xenia, Ohio
    Oh I don't think you can add a second user on that phone. For now until it is fixed I think your only option is to make sure you only have one of the programs installed at a time.
    Sent from my SM-N920V using Tapatalk
  14. Frank chrome
    That's exactly what I have. I only have one app installed which is litchi and nothing else and I does not connect which is my original problem.
Similar Threads - Cant connect litchi Forum Date
Cant connect to litchi app Phantom 4 Discussion Jun 22, 2016
cant connect p4p to assistant Phantom 4 Pro Help Jun 8, 2017
disconnected cant fly Phantom 4 Help May 26, 2017
Professional Cant connect to camera... Can i use the bord whit other hardware Phantom 3 Help Feb 12, 2017
Cant connect the craft (VERY strange/different problem) Standard/4k Discussion Feb 12, 2017
