CANT CONNECT TO CAMERA
Discussion in 'Standard/4k Discussion' started by Hvlios, Oct 2, 2016.
  1. Hvlios
    For reasons uknown, My galaxy s5 won't detect my drone on the DJI go app. I'm pretty sure this is an android marshmallow porblem.
    I have reinstalled firmware, downgraded it. reformatted sd card several times, relinked my controller, reset the wifi, redownloaded the app. Nothing works but for ios it works fine.
    Someone please help, i want to try and fix this before i have to send it back to dji for repair.
  2. RodPad
    Pacific,NorthWet, 97031
    Welcome to the Forum!
    If ios is working its not the Phantom. The remote control produces your signal that your mobile connects to. You don't need phantom powered on.
    If your galaxy can't see the signal? and ios does, then it is not the problem with the (remote / phantom).
    Is this the actual problem, or can the galaxy see the WiFi signal, but just can't connect?
    Rod
    Added: 60+ views, and nobody could help. :rolleyes:
  3. Hvlios
    I said i connected to it but i don't see the camera option. i tried everything including restoring my phone and downgrading my android os. im sending it to dji for repair.
  4. mdowney58
    Mountain City, TN
    If my memory serves, right after the Marshmallow update, people were reporting that they had to turn something on....developer mode or something?
    Sent from my Verizon Galaxy Note4 using TapaTalk
  5. Hvlios
    If it was only that easy, i had developer options and and i had usb debugging on. nothing worked :( it will get picked up today to get sent back to DJI for repair.
  6. Hvlios
    I also tried downgrading to lollipop in case marshmallow caused the problem. Same thing happened
  7. Darrell E Lyons
  8. Hvlios
    Well its on its way to DJI, so ill see what happens when i get it back.
Similar Threads - CANT CONNECT CAMERA Forum Date
Professional Cant connect to camera... Can i use the bord whit other hardware Phantom 3 Help Feb 12, 2017
cant connect p4p to assistant Phantom 4 Pro Help Jun 8, 2017
disconnected cant fly Phantom 4 Help May 26, 2017
Cant connect the craft (VERY strange/different problem) Standard/4k Discussion Feb 12, 2017
cant connect to app Pro/Adv Discussion Jan 14, 2017
