- Joined
- Jul 8, 2015
- Messages
- 186
- Reaction score
- 35
- Age
- 31
Hi,
It's been one year since I haven't flied my P3A, and today I decided to test it before going on vacation. I tried to connect my iPhone 6S (iOS 9.3.2) to the controller with the same Apple cable I've always used, and nothing worked. The DJI Go app didn't detect my phone. (or.. my phone didn't detect the controller for some reason...)
I thought it would be good to update my P3A, thinking it would fix the problem. I think the update failed too. The .txt file showed "abort" four times and "success" once. Now I'm completely lost. The controller and iPhone can't recognize each other, I don't know my Phantom 3 current version, and I don't even know if it actually updated successfully or not. (I since deleted the text file, as I tried to downgrade to v1.7)
What can I do now? How can I get a "clean"" and working firmware, be able to connect my phone to this **** controller and fly that bird??
Thanks in advance.
EDIT: just tried to "re-update" the P3A to latest version. Here's the text file:
Packet: P3S_FW_V01.04.0010.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
Result: Abort.
========== 2016.07.27 20:35:47 =====================
Result: Abort.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3S_FW_V01.07.0060.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Upgrading ...
Result: Success.
Thanks in advance.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Upgrading ...
Result: Success.
