Cannot get into calibration mode after downgrade
Discussion in 'Phantom 2 Vision + Discussion' started by r0ot5, May 26, 2014.
  1. r0ot5
    Hi guys,
    I've downgraded my P2V+ from 3.04 to 1.08 but sincerely I did I cannot get into calibration mode. The remote works fine (can start the motor) but I didn't find a way to get into calibration mode.
    I'm back to 3.04 for new until I get figure out why. Any of you have an idea why?
    Thanks,
    r0ot5
    Sent from my SGH-I337M using Tapatalk
  2. BlackTracer
    Winter Park, FL USA
    With 1.08 I find I have to watch the lights very closely while moving s1. Sometimes it will go steady yellow for only a moment as I move the switch again because I didn't stop moving the switch when it went steady yellow. So it goes back to flashing. I have always been able to catch the steady yellow though and calibrate even if it takes a few extra switch cycles. Have you tried in inside on a table? It might be easier to do there or at least practice.
  3. r0ot5
    Thanks BlackTracer, I will test it out.
  4. MikesTooLz
    Miami, Florida
    Supposedly 3.04 cannot be fully downgraded.
    Personally I don't think its a good idea to install firmware from another model phantom. Its lucky that they are so similar and doesn't make the phantom a paperweight.
  5. cougar
    Great White North
    Any idea what can be problematic?
    I have downgraded from 3.04 to 1.08 and not seen any issues what so ever.
    Might be that I am on a MAC and no drivers needs to be installed?
  6. DrJoe
    I have successfully downgraded from 3.2 to 1.08 with no issues.
    Reason to downgrade is simple: higher speed descents, no "airspace" limitations, steadier flying/position hold.
  7. BlackTracer
    Winter Park, FL USA
    My P2V I bought in March came from DJI loaded with 1.08. While you are right that the plus is a different model, the differences do not lie in the flight control system. The only differences lie in the camera system. 1.08 is as much for the P2V+ as it is for the P2V.
  8. r0ot5
    I've try everything and I'm unable to get into Calib Mode, back on 3.04 and it's fine....not sure why it won't go into Calib Mode....
Similar Threads - Cannot calibration mode Forum Date
Cannot complete the Assistant 2 calibration tool Phantom 4 Pro Help Dec 20, 2016
Cannot get calibration to work General Discussion Jun 16, 2016
Cannot Get Quad To Finish Calibration Or Start Motors... Phantom 2 Vision + Discussion Jan 12, 2015
Cannot initiate GPS Calibration Phantom 1 Help Dec 25, 2013
Failed Compass Calibration - Cannot Fly Phantom 1 Help Jan 19, 2013
