Can you use RTH to get good camera shots?
Discussion in 'Pro/Adv Discussion' started by Phantomix, Feb 14, 2016.
  1. Phantomix
    Weston, MA
    I like to be able to control the camera and not having to control the drone if I am aiming to get really nice shots, I will use orbit or follow me and litchi and stuff but would I be able to fly it far away from where I am (ex. 300-500m) and start return to home to be able to focus on controlling the camera while it returns to the home point, and if the battery gets too low I cancel return to home and fly it back faster?
  2. Michael Humphrey
    In that case I normally use home lock. You are able to steer yet return at altitude until you are over your home point.
    RTH is nice but that annoying beeping is for the birds.
  3. CaptainDrone798
    Canada
    You could but I would suggest you use Home Lock instead. The drone will come back to you at the speed you hold down the right joystick and you can control the camera and even the orientation of the drone as it returns to your position.
  4. Msvet
    If you are on an android device get Litchi in the Play store. It costs $20 bucks but is so worth it. It is built for autonomous flight using the camera and video to get the best possible shots. Go to their website and download the manual (easy read) and the you will understand. It is being ported to ios but only waypoints and orbit are finished.
    I have been flying Litchi about 6 months and use it most of the time now. Especially when the mission is photography or cinematography. Litchi has now added a new finish action "Reverse" and the ability to change cruising speed while a mission is running. This might do what you are looking for. I run a Samsung Tab S2, WiFi, GPS. Litchi also uses all 32 channels.
    #4 Msvet, Feb 14, 2016
  5. With The Birds
    Australia
    I kike the beeping...
  6. With The Birds
    Australia
    +1 for home lock and would consider course lock also.
Similar Threads - RTH camera shots Forum Date
Export 3d camera data to Google Erth > Mission hub Pro/Adv Discussion Apr 22, 2017
Litchi (and litchifly/hub) how to set POI camera facing earth vertically? Phantom 4 Pro Help Feb 22, 2017
Is it worth upgrading my 2.7k for a 4K camera for photography? Pro/Adv Discussion Sep 28, 2016
Camera aside is the P4 worth the extra $200? Phantom 4 Discussion Sep 24, 2016
match FPV in Goggle Earth w/aircraft camera? Pro/Adv Discussion May 12, 2016
