Can you determine video settings afterwards?
Is there a way to determine which settings were used to take a video? Like which of the following were used:
  • Style (Standard, Landscape, Soft, etc.)
  • Color (Classic, D-Log, None, etc.)
  • White Balance (AWB, Sunny, etc.)
Possibly in the metadata of the video file or somewhere on DJI GO? Captions don't show anything.
No. It is more for video and audio media.
This an example from an mp4 file.
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 3.13 GiB
Duration : 19mn 49s
Overall bit rate : 22.6 Mbps
Encoded date : UTC 2016-02-18 16:30:24
Tagged date : UTC 2016-02-18 16:30:24
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=13
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 19mn 49s
Source duration : 19mn 49s
Bit rate : 22.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 29.940 fps
Maximum frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Stream size : 3.11 GiB (99%)
Source stream size : 3.11 GiB (99%)
Language : English
mdhd_Duration : 1189590
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 19mn 49s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 18.1 MiB (1%)
Source stream size : 18.1 MiB (1%)
Language : English
mdhd_Duration : 1189588
argues
