GRCT42 said:
Any suggestions on 2.4 ghz FPV solution?
Therein lies the issue as most systems use 2.4 Ghz for control, and 5.8 Ghz for FPV. On the Vision/Vision+, this arrangement is reversed. Below are links to some 2.4 Ghz, 1.2-1.3 Ghz, and 900 Mhz FPV systems listed on HobbyKing. I have no experience with them, and I am sure there may be others available from alternate sources. The Vision+ App will no longer function, and you will have to use a FPV monitor compatible with your choice of FPV system.
**Note if you are going to completely ditch the Vision+ FPV system, you can save a little weight and internal space by removing the Wi-Fi module, and even the Wi-Fi antennae, from within the Vision+. That would save a little on power as well.
2.4 Ghz FPV Systems @ HobbyKing:
http://hobbywireless.com/24-ghz-systems-c-117_88_91/
1.2-1.3 Ghz FVP Systems:
http://hobbywireless.com/12-ghz-13-ghz-systems-c-117_88_90/
900 Mhz FVP Systems:
http://hobbywireless.com/900-mhz-systems-c-117_88_89/
