Can the transmitter be programmed to buzz a battery alarm?
Discussion in 'Phantom 1 Help' started by FrankB, Jun 8, 2013.
  1. FrankB
    Wondering if anyone knows if it's possible to program the Phantom so that the transmitter buzzes an alarm when the battery is low.
    If not, I hope DJI is listening and will put this on a wish list.
    Also, does anyone know if the propellor nuts screw on clockwise, like most nuts, or counterclockwise, or both. The propellors were put on by the dealer and are quite tight, and I so I can't figure out what direction I have to turn to get them off, and I don't want to try too hard for fear of breaking the blades.
    Thanks in advance.
  2. auck
    San Jose, CA
    Re: Can the transmitter be programmed to buzz a battery alar
    no buzz.
    right to tight, left to loose.
  3. Gizmo3000
    Sherman Oaks, CA
    there are some small devices you can attach to the battery balance lead that will buzz when a battery gets low.
    (the Phantom transmitter only transmits,. it cannot receive signals)
    The phantom uses regular nuts - clockwise to tighten, counter clockwise to loosen.
    keep those nuts on snug when you put the props back on!
  4. DeweyAXD
    Oxfordshire, UK
    It is a good point though. Do any of the mid range TX's like the T8J have capability to recieve such a signal or are you looking at the pro gear for that? I would love to have an LED indicator on the TX that shows me the LED output of the Phantom. Wishful thinking maybe?
  5. FrankB
    Changed this post to a question:
    Does the Phantom have two way communication with the transmitter?
  6. auck
    San Jose, CA
    not entirely true. you can turn on the transmitter without powering on the phantom and the transmitter will beep to indicate that the throttle is not all the way down. so this suggests that it is the transmitter itself that does the check for the throttle position. it is the same with the futaba 8J transmitter.
  7. tanasit
    RE: Wondering if anyone knows if it's possible to program the Phantom so that the transmitter buzzes an alarm when the battery is low.
    If I only read the statement above, I'd say yes the TX will beep when the battery is low BUT its own battery not the one in the Phantom.
    Anyway, stock TX doesn't have that feature. My Spectrum DX8i came with a telemetry & sensors that will send the signal to the TX screen and some of them can be set to either sound the alarm or vibrate or both when a curtain level of a particular value is reached. Even though swapping to a new TX is not that difficult but costly. The next best solution is to get :
    http://www.hobbyking.com/hobbyking/stor ... _V3_0.html
    You will get the job done with a small monitor attached to the Phantom TX antenna that you can set it to beep when a cell is below xx.x volts or total pack is below xx.xx volts.
    I also use the optional soft antenna for easier installation and convenience.
    http://www.hobbyking.com/hobbyking/stor ... enna_.html
    I also use the optional temp & amp sensor for my other multi-copter to monitor the battery temperature and the capacity left in flight.
    http://www.hobbyking.com/hobbyking/stor ... dd_on.html
    And since I have more than one multi-copter sharing the same TX, I ordered additional telemetry TX for each.
  8. FrankB
    I suspect that all communication may be only one way- you tell the Phantom to rise by pushing up on the joystick, it sends a message to the drone telling it to go up; you push the right joystick forward, and the transmitter sends a message to the drone to make this happen, etc.
  9. koviatt
    From another post:
    I am using a spectrum AR8000. It works beautifully with my dx8 radio. All the functions that are built into the stock phantom radio can be programmed (gps, atti, rth, and ioc). I also installed a telemetry module and have altitude and battery voltage feedback real time. I also use the X1 channel to control the pitch of my gopro camera (have a dual axis gimbal installed). I have my telemetry set up to warn me (beep and vibrate the dx8) when my battery voltage reaches a certain point. Very helpful when you are 2000-3000 feet agl flying fpv!
    Kent
  10. Racklefratz
    In a stock Phantom/transmitter, communication is one way. There's no transmitter in the Phantom, and there's no receiver in the "transmitter" (which is why it's called a transmitter and not a transceiver).
    On your question about a transmitter low battery alarm, I'm of the impression it comes that way. In the Quick Start Manual, pg 16, under "Transmitter State Introduction", the last item reads "Low Battery Alert - Need to change the battery" and the indication is "BB..........". I haven't run mine down yet, but I interpret that to mean it beeps.
  11. Racklefratz
    OK, folks. So there you go - whoever that hotshot is "flying fpv at 2-3000 feet agl" - he and his idiot buds are the ones who will eventually get this hobby banned when a real airplane that belongs at that altitude smacks into one of their machines and someone gets killed. It's coming.
  12. FrankB
    Yes- just ran through my first set of batteries- lasted a long time, even left them on accidentally one night.
    The Beep-beep......Beep-beep......Beep-beep alerted me that it was time to change. Abbreviated BB....BB....BB....BB
  13. FrankB
    I agree- or when the first terrorist attack with a Phantom is launched- remember, even the stock version is capable of carrying enough high explosives to do a lot of damage.
    And then there's the privacy issue- haven't heard too much about the paparazzi discovering Phantoms in the Hollywood hills- but when they do, that will also lead to major restrictions.
    Better enjoy it while you can.
    Remember, when the automobile first came out- there were no licenses, no driver's test; nothing. Even in the 1930's, my dad just went to the government office, plunked down his $5, and got a license.
Similar Threads - transmitter programmed buzz Forum Date
Multible FPV goggle on 1 transmitter Phantom 4 Help Jul 28, 2017
Standard Can I link 2 transmitters Phantom 3 Help Jul 27, 2017
Tripod for P4 Transmitter Phantom 4 Pro Discussion Jul 23, 2017
Dji avl58 transmitter and elvid skyvision help please. FPV (First Person View) Jul 22, 2017
DJI Phantom 3 4K transmitter, props, charger, Canada shipping only Classifieds Jul 8, 2017
