DO NOT install the new 2312A motors onto a Phantom 3 Professional/Advanced aircraft with the old central board (Spare Part NO. 33). Likewise, DO NOT install the old 2312 motors onto a Phantom 3 Professional/Advanced aircraft with the new central board (Spare Part NO. 96). Doing so will likely damage the aircraft. As a general rule, match the old motors with the old central board and the new motors with the new central board. Follow the steps below to replace the motors.can i mount 2312 on pt96 motherboard?
The ESC error may or may not caused by faulty motors. My experience is when my AC battery goes lower than 50% I will get the esc error and the motors won't start. You may want to check your firmware as well to see if it helpsI buy part96 and Now i bit new 2312a
My part33 esc error e remove and add part96 and i buy 2312a
now I ordered the new card! I was afraid of falling while I was flying! now I'll have everything new and I'm calmer
Since you had already ordered the part96 central board and 2312A motors I think it's better to replace the old version because 2312A is more efficient. It's also difficult to source new genuine 2312 motors even from China. I would not buy used motors because they may have been crashed and have bent shafts and who knows, to be safe always go for
Is there any way to test the engines?
As far as I'm concerned there is no easy way to test the motors. A guy made a how-to video to test motor vibration
Another video using a laser
To balance the motors see this video (it's kind of troublesome to do it)
To avoid doing all these checking and balancing I would rather buy new motors
