Can I link 2 transmitters
My P3 came with 2 transmitters due to a fly away. Can I link both to work with the drone.
Is that what the master slave thing is in the go app?
Only one remote controller can be linked to the Phantom at a time. When you switch remote controllers, you'll have to relink the remote controller before using it.
So it's a big deal to switch back and forth. Will loose any setting or gimbal adjustments when I switch back to the radio I made them on. .
All AC related parameters are saved on AC, so you should not worry but yes for your satisfaction, check all the important parameters once and verify that they are as what you wanted.
But if you have 2 working stock controllers, there is no reason to be switching back and forth between them. While linking is usually straightforward, there is always the chance that something will go wrong. Why give Murphy a chance to bite you?
wkflysaphan4
